today was accelerating lost power started misfiring sounds like a scooby burble same at idle cut out a couple of times it hesitates on acceleration at 20mph 1st gear 40mph 2nd gear if i back off the throttle it starts pulling better nightmare when doing a hill start
have changed throttle body x2 distributor fuel filter plugs are brown tried fuel additives 97ron fuel and re routed lambda cable it is gradually getting worse
