8 extended wheel studs
Hey, Anyone got any extended studs they don't need/want?
otherwise it's an ebay job :rolleyes:
Big tanks!
I think pollys got a small guide/info in his build
As far as im aware, drums off, either brake shoes and mechanism out or the main assembly off the hub to make it easier
Do you know em out with a hammer etc? hydrolic push?, ill do a search ..... and if i find it ill post here the link if ok!!!
J
No need to take the shoes out. Just undo the rear hub nut, slide the hub unit off the spindle, secure on vice and the studs just hammer off.
Place new studs on hub and use the wheel & nuts to 'pull' the stud back into the hub. Then refit the hub onto spindle
Sweet!! cheers!!!
J
