Hello,
I've been trying to install an Ldperformance Launch control device on my 2000 nissan micra k11 distributor version (not coil on plug).
I need to install it between the 5 volt coil signal wire coming from the ecu to the distributor but i cant find which one it is. I've installed it between the Green/white wire on the distributor but it didn't work and when i measured the voltage it was giving 15volts and not 5 volts.
Does anyone know which wire from the ecu is the 5v signal to the ignition module wire?
Here are some pictures of the wire diagram of the launch control device.
