markbognor Ex. Club Member Club Member Dec 20, 2012 #1 I guy on another forum is hunting large diameter brake disks for track biased Scirocco build. Whats the largest diameter disk in 4x100 that you have come accross regardless of C/B or bell depth. Cheers.
frank Club Member Dec 20, 2012 #2 the almera guy,s use a 280mm disc with their willwood brakes i believe mark (gto disc maybe ?)
Skinner_87 Dec 20, 2012 #4 Wilwood do a 310mm for the GtiR http://www.motorsport-tools.com/nis...-brake-kit-midilite-310mm-discs-p-265344.html
frank Club Member Dec 20, 2012 #5 markbognor said: Pontiac? Click to expand... ah sorry mark, mitsubishi fto calipers and clio 182 discs are the 280mm mera upgrade, and the willwoods + 315mm for bigger still apparently
OP OP markbognor Ex. Club Member Club Member Dec 20, 2012 #6 I knew you didn't really mean Pontiac GTO, and had guessed Mitsubishi (surprised to learn that they are not 114.3). Is it clio 182 that are 315?
frank Club Member Dec 20, 2012 #7 markbognor said: I knew you didn't really mean Pontiac GTO, and had guessed Mitsubishi (surprised to learn that they are not 114.3). Is it clio 182 that are 315? Click to expand... the fto discs are 114 mark, they use the fto calipers and clio discs ^
