Any one know if a 3door and 5door rear arch is the same shape as I’m trying to find a replacement outer panel but all I can find is 5door and mine is a 3door!! Cheers
the arch is the same shape but the panel still may not fit. it will also be a bitch to weld in and not distort the panel.
have you tried looking for a rear quarter panel?
other option is as ever the scrap yard where you can drill out the spot welds and cut the panel closer to the swage line making your life easier.
