So i bought myself a k10 micra as a cheap reliable run about while i finish fixing my megane.
I said i wasnt going to modify it but i just cant help myself so the plan is:
de wipered
Lowered on jom coilovers for polo 6n
matt black
13x8 wheels with 225/45 tyres
rangerbob arches
sr20de conversion
I forgot to take picture of removing rear wiper but only took 10mins and used a grommet in hole for now until i get it welded up properly.
I got polo 6n jom coilovers and manged to modify the fronts to fit by drilling out top mount and drilling a hole in shock 5mm below.
Not sure if you can see in picture but by fitting the fronts its caused both front wheels to point outwards while steering wheel is straight.
Tried taking it for a drive and its so bad the tyres are screeching just driving forward slowly.
Just need bushes on the rears to be cut down a bit and they should fit on.
Got my new wheels today Revolution 4 spokes 13x8j they have 175/50 tyres on so once ive worn out ill put some 225/45 on for lots of grip.
Alot lower profile than standard steels so sitting even lower.
Sticks out a bit so just need to order some new wide arches before i fit them all.
de wipered
matt black
rangerbob arches
sr20de conversion
