1988 1.0L K10 - cab heater cable clips
- Strange 'gull-winged' mechanical cable clips/grips ( see photos )
- Anyone know where these can be bought in the UK ??? ( or a substitute ( missing clip behind heater/cold panel, so doesn't heat cab)
Thanks - Steve Mac
OP
OP
K10-1988
- It would be good to source these 'brake-type' cable clips = for the cab heat/cold switch-lever.
- However,... closer inspection proved the LOST clip was due to the PLASTIC molding being broken. I tried various glues, but the split parts wouldn't take any strain. - I used a cut down Electrical connector strip to grip (screw down) unto the outer cable plastic shield, and a tie-wrap to anchor it to the stronger remaining stub of the assembly.
( having fed the opposite end down & anchoring to the lever of the heater/cold flap mechanism - I placed the (dash/console) operating lever in the far-right HOT position & then - while pushing down on the flap-lever below, - anchored the plastic outer-shield into the remaining 'gull-winged' clip shown above. )
