Hi
Not really certain if I have a problem or not?
I have only noticed this on cold start ups when the engine is left running in cold conditions (in neutral) to defrost the screen.
The engine will idle as it should then every so often there is a surge and the revs shoot up (as if you'd given the accelerator a good press).
Has anyone else experienced this? Is it normal? If there is a problem what could the cause(s) be?
