kennierobo
Buy & Sell Member
very simple I know but a couple of questions anyway,
the ecu unit for the 1.3 and pickup ring are from a V reg going into a R reg pre facelift whilst the ecu unit would be plug and play the pick up rings are not the same I also have a none nats 1.3 ecu unit so to over come the dilema of nats yet again would it be just a simple case of changing the engine side of loom only to a none nats set up.
2nd part realating to another project I have purchased the 1.6 micra from brooney and would like to get it completed and not have to undo all the hard work thats been done so far engine side is complete he removed
the micra wireing loom from front to back replacing it with that from a
primera anyone
that has done this will know what wires need cutting and modding to get it up and running so any info on that front would be taken on board. If i cant get it running then I will break it and sell off all the parts or worse still scrap it. wiring for me is hard at the best of times due to colour blindness so if its simple then great if not then an open book as its not happened yet.
primera anyone
