1.3 engine/gearbox/driveshafts
george
im looking for all the parts to put a 1.3 engine in my 1.0: engine, gearbox, driveshafts,ecu. or a smashed up 1.3 micra for sale. cheers
george, you would need the g/box brackets, gearchange and front to rear x member too :).
or you could fit an engine only, like mine :)
ive got a 1.3 auto block (stengthend block over a manuel good for a turbo build ;)) in bits...needs rebuilding, just the engine though..
all you will need then is a new crank, gearbox, and shafts...take it for £30 even has a powersteering pump.
Should have everything you need with a choice of engines. Would you collect or want the parts sent by courier? Give me a ring if you want to have a chat
01865 748000
Matt
