curtis Ex. Club Member Jun 17, 2008 #1 Just need someone to say a defo yes to this.... Will a K10 1.2 engine fit straight into a 1.0 K10 with no modifications at all? Inlcuding loom etc.... thanks Curtis.
joesouthgate Super Moderator Moderator Club Member Jun 17, 2008 #2 I asked this a while back - http://www.micra.org.uk/showthread.php?t=20226
OP OP curtis Ex. Club Member Jun 17, 2008 #3 haha that went slightly off topic in there lol So its a striaght swap!
superls K10 Tuner Jun 17, 2008 #4 yes curtis it is a direct swap, nut for nut bolt for bolt, connector for connector, providing its not an ecc equipped engine that is, lol
Speedle Ex. Club Member Jun 17, 2008 #6 yes, the rear engine mount may need to be swapped for the 1.0 one but its more or less the same. but be warned the 1.2 wont handle the power from the setup you have for long.... you've been warned
OP OP curtis Ex. Club Member Jun 17, 2008 #7 .........but its the engine that pietro and sammyboi have been using.......
Speedle Ex. Club Member Jun 17, 2008 #8 in that case itll be fine as that engines (pietro's one) had a massive amount of internal work done to it
OP OP curtis Ex. Club Member Jun 17, 2008 #9 Thats what i was thinking.....now its for sale i might as well reunite the webers
OP OP curtis Ex. Club Member Jun 17, 2008 #11 :glance: lol Im getting the webers tuned straight after anyway....£85 for rolling road tune
OP OP curtis Ex. Club Member Jun 17, 2008 #13 I know....some place quoted me £210 for it....shows that searching around does work also they are closer to me...
