Can heater leds be changed
After all this talk of me changing my dash leds I was just wondering can the heater control leds be changed? I was thinking of doing the one which you select where you want the air to come out of and the intensity (not the actually hot/cold dial in the middle though)
Not 100% if you can get to the bulbs from behind...but im pretty sure you can remove them once the trim panel (bit with all the symbols on it) has been removed, its only lightly held down with sticky anyways.
They are bigger bulbs than the dashboard cluster ones though. :)
My old trim piece was ######ed by previous owner (no idea how), i went to scrappies and gently removed a decent one (took care not to remove the sticky from the plastic / get glue residue covered in fluff etc)...got it home ripped the old one off and replaced it with the new scavanged one...been on for months now no probs.
So i guess im saying, if your careful...yes :D
Write your reply...
