Had to buy it on eBay. The code is 0780 if it helps someoneHey, maybe someone can help me, just bought my micra and the previous owner doesn’t remember the radio code, and I can’t find it anywhere
The Serial number is: HY68N04483
Part number: 28185 3HN4C
Prod Date: 16.08.17
Hi, Thank you so much, it worked perfectly! Really appreciate your help!Hello,
Code is . . 0823
Hello,Hi, would you be able to get the code for.
BP738398446159
7647383318
It would be much appreciated.
Many Thanks.
Thank you so much. It worked perfect.Hello,
Code is . . 6630
Hiya . Found code myself .K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
BP536258427297 pleaseK12 Radio Code Thread
HELLO ?BP536258427297 please
HELLO ?
Hi I’m after the radio code for micra K12 with BP number as above the battery went flat and there’s nothing in the space at the back of the manual thanksHELLO ?
Hello,Hi I’m after the radio code for micra K12 with BP number as above the battery went flat and there’s nothing in the space at the back of the manual thanks
If anyone could help with this I would really appreciate it.Hi All,
Would someone be able to help with a radio code for a Nisan Micra I have recently purchased second hand.
Serial#: DW3CN27382
Part#: 281853HN4B
Prod Date #: 13 12 17
Any help would be much appreciated.
Thankyou very much it worked and now I have musicHello,
Code is . . 5111
hi guys, can you please help me with the radio code for my nissan.K12 Radio Code Thread
Hi, try 4359 or 0359.....Hello friends.
Unfortunately, I lost my radio code for my Nissan Micra 2004 after installing a new battery, I hope you can help me.
BP334947263191
MM CD-K 7643349318
Thank you
Sorry for the space it’s probably bp7383a9262812I’ve recently got a new Nissan micra and they didn’t give me the radio code I was wondering if you could help me
Serial number : BP7383 A 9262812
I sent your code as a private message as requestedSorry for the space it’s probably bp7383a9262812
Hi, no problems, only one possible for your radio, 1061... :0)Hi,
Could you please help me with my radio code
Nissan micra
Serial number:BP5387 61150934
Let me try.Hi, no problems, only one possible for your radio, 1061... :0)
Hi does anyone have a code for BP 5384 7 1196297?Hiya . Found code myself .
"Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code."bp7383 8 7795855 radio code please?
Try 8759 or 0759......bp7383 8 7795855 radio code please?
Hiya, just bumping this in case it slipped through the cracks. I’d be very helpful for any help. Thanks!Hello,
Would really appreciate some help for a code.
Serial number is BP538769684853
Thank you so much in advance!
Only just seen this, 0438 should solve your problem....Hiya, just bumping this in case it slipped through the cracks. I’d be very helpful for any help. Thanks!
Hello,Hello can you help me? Thansks if can ;-)
Need code for Micra K12, BP5389 7 1343082
Try 3019 or 1019......Hi everyone,
Micra 05
Sn. BP3349 47331009
Part number: 7643349318
Code please:
Missing the noise lol
Thank you
BP738398446159
7647383318
Many Thanks.
Hi would you be able to help, I dissconected my battery to do some welding and now my radio needs a code.Hi, would you be able to get the code for.
BP738398446159
7647383318
Many Thanks.
Hi, try 4511 or 0511.....Hi would you be able to help, I dissconected my battery to do some welding and now my radio needs a code.
Bp738398788613
7647383318
Anyone can help I’d appreciate it.
Hello can you help me too? I have nissan micra 2007 bp5384 7 1219355Hello,
Code is . . 6630
K12 Radio Code ThreadHello,
My Dad had the battery changed on his K12 -'microwave', which has locked the radio. I wondered if someone could help me with the code?
The radio is a Clarion:
Part number: 276-0034-54
Serial number: PP301MB 0011909
Thanks so much!
B
