WTD CGA3 engine
As above looking for a CGA3 engine to build a 1348cc from.
Ideally just a short block is needed.
Shipped to the Isle of Man but I can sort a courier no problem.
Skinner
Hi
I have a micra 1.4 SE+ that needs rear axle. You can use all parts apart from the axle obviously.
If your interested give me an offer that I can't efuse.
Regards
Bump, still looking
Please note i am looking for just the engine not a whole car. Im on the Isle of Man so £400 just to travel to pick it up isnt an option :)
Skinner sorry to piggyback on your thread but.....
I too need one of these, ideally in the SE, but i do travel around a bit for work.....
Also can you fit the 1.3 'dizzy' head ok as the 1.4 bore is 1mm bigger? Our micra is preface lift so wont run with the coil pack system.
Yes the dizzy head will bolt straight on :)
