WTB: Uprated Fuel Setup
CMF_mycra
hello boys..
it time to retire the stock setup(new genuine pump and reco injectors if any1 wants them).
I am after anything that will support around 180hp+(Injectors/Rail/Pump). don't really care what setup/type as long as they are A1 goes straight on, minimum stuffing around....
i will be keeping N/A
also any tips please feel free to comment.
cheers
CMF_mycra
by the way current motor is 258 deg cams+adj gears, flowed head, double valve springs, titanium retainers, cg10 pistons, sr20(70mmt/b, flowed inlet mani, tuned on modified nismo ecu with nistune t4 dual board. only fuel mod is regulator.
sps is making me a set of raised hi comp pistons to bring up comp ratio.
i notice every time i start, need to wait 15sec+ for pump to pickup pressure or wont start....
CMF_asdame
i've just fitted a walbro 255 pump on my 160bhp micra turbo cos the 2nd hand skyline GTS-T pump was making it lean out at the high end. its fixed the overall mixture issue now.
see on my blog here at post #1766
http://www.micra.org.uk/threads/35251-PollyMobiles-Rebuild/page36
pump was for a facelift mount & connector plug and twas smaller than my prefacelift pump so had to do a slight mod of the rubber mounting.
CMF_gumbi
pretty sure ndxxx will have some 375cc ones in rail to fit because i just braught most of his turbo kit... if thats any help
CMF_mycra
asdame WROTE:
"i've just fitted a walbro 255 pump on my 160bhp micra turbo cos the 2nd hand skyline GTS-T pump was making it lean out at the high end. its fixed the overall mixture issue now.
<a href="http://www.micra.org.uk/threads/35251-PollyMobiles-Rebuild/page36" title="http://www.micra.org.uk/threads/35251-PollyMobiles-Rebuild/page36" target="_blank">http://www.micra.org.uk/threads/35251-PollyMobiles-Rebuild/page36</a>
pump was for a facelift mount &amp; connector plug and twas smaller than my prefacelift pump so had to do a slight mod of the rubber mounting.
cheers mate, been great help reading ur build tread. Got them injectors sorted now. i might source out a new gts-t pump. mine is n/a though should be enough hey..?
CMF_gumbi
LowMicra WROTE:
"gumbi WROTE:
"pretty sure ndxxx will have some 375cc ones in rail to fit because i just braught most of his turbo kit... if thats any help"</div>
are you going to run standards then??
is that a joke...? i have a cga fuel rail so i need to find some injectors to suit
