WTB: spark plug leads and o ring set
CMF_tris
hey, to fix my problem i need new leads and a rocker cover o ring set (for the top of the spark plug wells)
if anyone has these or can tell me where to get them from that would be awesome!
cheers, tris
also, if i take off the rocker cover, will i have to replace the gasket? or can you clean it off and put it back on with some silicone??
CMF_asdame
its easier to grab another cover from the scrappies than replace the spark o-ring seals cos the thin inside plate holding the seals in are bolded to the rocker cover, difficult to remove without damage.
the cover/cylinder head seal can be cleaned & siliconed back on if the rubber's intact
