CMF_mycra
» CMF MemberHi does anyone have a set of high compression pistons laying around or any suggestions?
frank2 WROTE:
"cg10 ftmofow
mine has cg10,s in and a better inlet cam, and is somewhat quicker than my old (16.0 sec 1/4 mile) blue car
they give you nearly 12:1 c/r apparently <a href="http://www.micra.org.uk/threads/43041-Hi-K11-gurus.-i-have-cg-cga-questions" title="http://www.micra.org.uk/threads/43041-Hi-K11-gurus.-i-have-cg-cga-questions" target="_blank">http://www.micra.org.uk/threads/43041-Hi-K11-gurus.-i-have-cg-cga-questions</a>
but you need to "press" the wrist pins out tho eh
frank2 WROTE:
"just the pistons mycra, the 1.0 rods are waaay too long
mycra WROTE:
understood, setup like this combined with aggressive moderate-work..can run off factory ecu?
mycra WROTE:
"that arent too bad at all...what piggy back are u using?
mycra WROTE:
"so pretty much you took the coolent sensor off the head, block it. then mount it inside the cabin and run a switch only to operate at high revs. correct?
mycra WROTE:
"Frank can you post a picture of the hot and cold sensors ?
mycra WROTE:
"haha il have a go at it once mine is all assembled up frank cheers
mycra WROTE:
"yeah finished the motor today... not the power i expected ..
gonna give the sensors a go
oh say picture your current motor... if you were running cg13 bottom but worked head what fuel pressor do you recommend?
frank2 WROTE:
"and k11,s run closed loop in entirety apparently (lambda controlled a/f/r,s) ie, they have no acceleration enrichment eh
SSUK WROTE:
They do have acceleration enrichment....
frank2 WROTE:
"SSUK WROTE:
They do have acceleration enrichment...."</div>
well here,s a quote from your friend ED (fusion)
"the OEM map of the K11 is closed loop through its entirety".
SSUK WROTE:
That's true but it's still got acceleration enrichment.
