WTB: Aftermarket Camshafts
CMF_Danvillan
Wondering if anyones has a set of aftermarket camshafts with bigger lift/duration eg: Tomei, etc. I know you get a set from perfectrun but didn't want to spend that much, so I thought someone may have a set laying around that I might relieve them of. If so please PM me.
Anyone had a regrind of there stocks cams done? if so who did it and how much?
thanks guys
Daniel
CMF_RTK
no longer made, and i think humphries? if not some other company Frank2 would know; what are you wanting them for? NA or Turbo?
CMF_RTK
Danvillan WROTE:
"So not much to be gained? Lower compression and more boost FTW?
just get a thinner head gasket ie copper made, and what kind of ECU do you wish to run?
CMF_Danvillan
Thicker? I've already increased the combustion camber with should drop it a bit and ill get a copper head gasket made. I'm going to get one from O'brien Aluminium who does copper gaskets between 1.2, 1.6 and 2 mm for $150. I'm running an EMS Stinger.
