Thanks a lot mate. I looked on the spoiler and bottom of it got plastic slider on each side. So i wont be drilling any holes. Will just bond it to the back and fingers crossed it wont fall off...Hi mate
I have a base LX that had no rear spoiler ( though it dose now ) and a Super S that has the wrap around spoiler from the factory. The only difference I can see ( and I am by no means an expert on this ) is my S has two grommets under the hatch at either side which when they are removed you can see the bolt heads holding on the spoiler, I believe the lower part of the wrap around spoiler is just bonded to the hatch......
Thats what i gonna do.....I cut all the studs & brackets off the spoiler and permanantly bonded it onto the boot with tigerseal
Comparing to the other car where the blanking plugs were fitted, covering the access to the fixings, it is obvious where the holes would need to be drilled, easily confirmed by measuring the hole centres for the fixing points on the spoiler..........AD9QMR's point was that his car has no spoiler previously fitted and so no holes in his hatch, so maybe not so obvious....
View attachment 51842 View attachment 51841 Hi mate
Sweet thanks sounds fairly easy I will be posting pics on here if I manage to find one for sale.Hey OLeary, the wrap around type spoiler has two studs protruding from underneath the top section, take the grommets out of your tailgate and drill a hole in the centers so the spoiler sits flush with the tailgate and fit nuts onto the studs, the sides can be secured with silicon sealant. Alternatively just follow pollyp's suggestion.
I'm back (didn't want to start a new thread) Just seen a wrap around spoiler on ebay but its being sold as part of the full boot lid, how hard do you reckon it would be to remove it? removing the top part should be easy enough if it's just 2 nuts but what about the sides?
It's a pretty big hole and definitely larger than the bolt, and the nuts have big washers on them tooHi guys, I am sorry to revive this old thread but anybody with a factory fitted spoiler could measure the diameter of the hole covered by the grommet? I would like to install a spoiler but would rather follow the official way. So the plan is to keep the bolts in the spoiler and to drill holes into the boot door.
Hi, yep, I know but I don't know the diameter of the hole. I'll have to buy the proper hole saw and some grommets. Would like it to look nice and clean just like coming from the factory with a spoiler.It's a pretty big hole and definitely larger than the bolt, and the nuts have big washers on them too
You won't need a hole saw, it's probably a 10 or 12mm drill bit and will fit in a standard half inch chuckHi, yep, I know but I don't know the diameter of the hole. I'll have to buy the proper hole saw and some grommets. Would like it to look nice and clean just like coming from the factory with a spoiler.
