A51jeremy Apr 28, 2012 #1 its ment for a 1L im just wondering if the fitment is the same on a 1.3 ? http://www.peterlloydrallying.co.uk/index.php?main_page=product_info&cPath=77_114&products_id=1518
mckenziecz Apr 28, 2012 #4 A51jeremy said: do you no if this will affect my oxygen sensors ?? Click to expand... no. the lambda doesnt move. its from the first cat. loads of people are running these systems
OP OP A51jeremy Apr 28, 2012 #6 quick question tho would this be a good mod for a 1.3 as its only a slight bore increas but it is straight tho ??? plz reply as looking into buying
mckenziecz Apr 28, 2012 #7 A51jeremy said: quick question tho would this be a good mod for a 1.3 as its only a slight bore increas but it is straight tho ??? plz reply as looking into buying Click to expand... I think its 1.75" bore, more then you even need on 1.3 n/a
OP OP A51jeremy Apr 28, 2012 #8 mckenziecz said: I think its 1.75" bore, more then you even need on 1.3 n/a Click to expand... cheers ordearing it now xD
Shaun ***StaGGeRed*** Apr 29, 2012 #9 Had the same system. Doesn't really increase performance as such but sounds beautiful. Not in your face loud with a bit of rasp at higher revs
