hi all, tonight my 2004 micra failed to start turned the key and nothing, done some digging on the net and c that the ignition switch is a common fault, was thinking about replacing this as its a cheap place to start, had a look and cant c how u release the barrel to get the switch from it, there does look like a pin that runs through the barrel but im unsure if this is what releases it, its about an inch from the end, hope this makes sense guys!
appreciate the help!
den
den
