Bought my first k10 about 10 months ago(1990 k10 canvas 1.2), ran great until a couple of weeks ago. Was drivning home from work and it just died out of nowhere about 5 minutes away from home.
Towed it home and tried to find out whats wrong with it.
It has good spark and compression and The carb bowl is filling up to The correct level.
It runs on starter fluid or when pouring fuel into The carb. The carb Will squirt fuel when pumping The throttle and Will fire up but only run for a few seconds.
Thought The carb Was clogged so i Bought a rebuild kit. Replaced all gaskets and o rings, accel pump, cleaned all The jets and soaked The carb in carb cleaner but it still acts The same.
Replaced all dry rotted vacuum lines and leak tested The intake gasket, i get good vaccum when cranking.
The car had sat in a garage for 14 years when i bought it so i have recently replaced:
Fuel filter
Fuel pump
Dizzy CAP and rotor
Sparkplugs and wires
Thermostat
Oilfilter
Oil and coolant
Watepump
Timing belt and tensioner
And it has been running Great until now.
I have NO idea what to try next please help, i really enjoy drivning this car.
Fuel filter
Fuel pump
Dizzy CAP and rotor
Thermostat
Oilfilter
Oil and coolant
Watepump
