CMF_cowboydave
» CMF MemberI was having problems with my cars idle so after searching the forum I found the tutorial on the dry solder joints. I re soldered the joints in the throttle body and put it all back together, the idle still doesn't seem great but might be better but the biggest problem now is it won't rev past 3K! I've had a look to see if everything was put back properly and it seems to be. The only thing is there is a small hose that doesn't seem to be connected anywhere (I've attached a picture) Does this go anywhere and if so could this be my problem?? Thanks guys
