Wiring Harness Gauges - ABS to Gearbox Sensor - Diagram for a Dummy
Hey Folks.
Sitting in the middle of the bush in Thailand, in the process of upgrading my March K13 - Does anyone have a Dummys Guide or Diagram showing what the wires do or are for, this is the connector into the speedo cluster. eg: Blue top = ABS Light etc - This is a for 2018 wiring harness. I would also be looking for the same for a 2012 harness.
Object of this is, I am still looking at various methods to upgrade my instrument cluster and if it means stripping and chasing wires to remove, then that is what i am going to have to do. My car is a 2012 manual with the speedo being run off the Gearbox sensor, so in my mind and I may be very wrong here, if I can find and chase the same wire here and get it pointed to the gearbox rather than the ABS system, it may work in theory ... unless i am completely missing the point on this 🙁 in which case i will hold my hands up and go back doing exhaust system and bodywork.
I have heard you can use a Dakota Digital Convertor, but finding a 2nd hand one here is impossible.
Ps, I have the full interior harness and can get my hands on any other parts / wiring etc pretty easily if i needed anything else.
