Wiring diagram K11
Hi All;
My k11, 1.0lt, vibe, blows the interior light fuse whenever I try to replace it. I have checked the door switch,light etc but all seem fine. The only other thing that does not work, is the digital clock in the instrument cluster. I now think that it may be a short circuit in the clock that is blowing the fuse.
Is the interior light and clock supplied by the same fuse?
Can anyone supply a wiring diagram?
Thanks.
Your in luck that im sat on thecomputer with a haynes manual next to me ;)
Interior lamp is not supplied by the same fuse.
F4 10A Interior lightening, audio, luggage compartment lighting
F22 10A Audio, Clock
Do you have the correct amp fuse?
Jay101.
Great, simple wiring, but I can`t see why the fuse would keep blowing unless theres a wire touching earth. I see the light is linked through items numbers 75,76, &77. Could you clarify from your manual what these are. Thanks for your help.
jaz
75 warning buzzer
76 key switch
77 deadlock unit
check connections could be shorting the circuit. As for the clock light, mine doesnt work either, its a common fault, ive tried to replace mine sunday and still had no luck,
