A little problem Ive found on my Super S is that more often than not if i start the wipers going they wont stop! The only way they will turn off is to turn the ignition off but even then if I turn the ignition back on 90% of the time the wipers will go again!!!
Im not sure if its the contacts in the stalk sticking or some other problem with relays etc?
Any ideas??
Any ideas??
