One of my wipers went down just before Christmas, drivers side too so pretty important, and I really should be looking at fixing it.
Did attempt it the day it happened. Basically the arm to the drivers side wiper has come off the ball joint at the central motor bit & was dry as a bone. Spent ages trying to get it back on, eventually packed it with some nice thick grease & ran it for a while to check it stayed put which it did.
Sod's law though & continuing my trail of misfortune, as soon as I got the scuttle panel back on & everything back together it just broke again once it had the weight of the wiper back on so I just adjusted the other wiper to wipe most of the screen & it's been like that for ages now...
Guessing the ball joint on the linkage is too far worn? Is it a case of just replacing the one arm or is the whole linkage system gonna need swapping out?
