will the smaller type 1.0 G/Box fit on a facelift 1.3 engine?
As it says in the title really,
I have a 1.0 96 k11 that im stripping for my mini conversion - From what i've worked out online this means it is a Pre facelift car / engine. Therefore has the smaller sized 1.0 gearbox on it with smaller driveshafts / Cvs etc. It has the mechanical speedo too which works in my favour.
So... i already have a 1.3 engine (dizzy drive) which is ready to run.. All i need to know is will they fit together? will i have any issues trying to put them together?
And my final question - do 1.0 litre engines have exactly the same mounts / fitting hardware as the 1.3s? Ive seen the allspeed subframes and for some reason they list them as 1.0 and 1.3 frames - they look exactly the same so im assuming they are refering to the early gearbox 1.0 size and the larger and newer 1.3 gbox / engine combos.
http://www.allspeedengineering.com/ - Have a look at the nissan section. Im so confused!
Thanks gang :)
