Been having the usual troubles with the boot coming opening and then not opening! And then opens by it’s self with the usual clicking sound. By pressing the anti hijack button we were able to get the boot open but after a few times with the wife being stranded with a flat battery I decided to check the door wiring and found a Black cable with gray broken under the foam. This I repaired with bullet clips.
But now I have fixed this broken cable we can’t open the boot, the car locks but the light on the anti hijacking switch is now permanently illuminated until pressed? I never even realized that there was a light in this switch? When in the car I press the switch and this light goes off! But by pressing the door button the car locks but this light comes on and wont go off until pressed. After charging the battery I put it back in to the car but the following day it was completely flat again!
With the boot locked shut will it be the micro switch? If so where is this micro switch hidden as I have removed the back panel but can’t see the big yellow label telling me where this switch is hidden?
