Will it still run ok?
CMF_miniobsessed
Hi guys,
Putting a cg13 into a new home and it would make it much easier if I could remove the idle air valve and waxstat cold start mechanism (for space reasons) from the throttle body...
Will it still run ok without these?
CMF_frank2
miniobsessed WROTE:
"Another question...
Will it cause any issues if I leave the idle valve electrically disconnected too?
Thanks again
i never tried it tbh mate, mine has the i/c/v removed to clear the topfeed rail, and then i blocked the hole under the t/b with a rubber pipe (the shape of the mani holds the plug in place)
with the idle control delete, the ecu uses spark timing to maintain a stable idle, but it is limited in scope tho (and may not cope with aircon or power steering)
CMF_miniobsessed
Thanks again Frank.
So by the sound of it your idle valve is electrically disconnected?
No worries about air con or power steering as they won't fit either (unfortunately)...
