will a cg13 head fit a cg10
As titled does anyone no if the head of a cg13 will fit a cg10 or if you can modify it to fit and what sort of gains you get from fitting it? Any help will be great I no the cg13 cams fit
Well in that case is there an option to create a big valve head or is the standard head capable of a high flow rate?
If there is no option for larger valves what is the standard cylinder head capable of in ported form?
Is there anywhere to compare camshaft profiles for the cg10/cg13 platform engines?
Many thanks
