will 175/65/15 fit in the standard K11?
HI there, just a quick one, will 175/65/15 fit in the standard K11? my standard one is 165 60 14 and I saw some post said that certain size in 15 will not fit in micra (hit the wheel arch while turning) my micra is standard, not lower or anything. advice please?
A 50 profile tyre on a 15 inch wheel is a maximum.
You may get away with 65 but I'd guarantee it'd rub on bumps and lock :)
use www.willtheyfit.com to work it out. 175/65R14 JUST fits, 185/65R14 will fit in the rear if you modify the bracket to hold the rear bumper on thats in the arch for clearance, but they look ridiculous...
I'm -75, and with those tyre sizes even running over white lines was enough of a bump to make it scrape. Getting in that field was pure heroic on my part, tyres were dead when they eventually came off... massive rubbing!
