CMF_White Knight
» CMF MemberWell!!!!! the beast is running but had problems getting it to idle when coming off power.
Lots and lots of adjustments to the Autronic programme and the Pintara throttle body but she nows revs up and comes back to idle ( 11OO rpm)without stalling. Timing is spot on and we did not do a power run as we ran out of time so will hit the dyno on Monday.No use doing a power run if its not 100% down low.
We can adjust the rev range to whatever we want. Have set max at this stage at 7000 rpm but can dial it up to say 8000 if we want. Tempting.Anyway will wait for the power run and make sure all is right up the top end and then maybe screw it up a bit and see if any gain. I am sure the motor can handle it.
Overall a good 3 hours spent getting everything right at the dyno shop.
Fuel rail fine Cisco. No leaks but did not expect any problems as Errol had it pressure tested before it was shipped over.
Beast sounds awesome on the few ocassions we ran it up to around 6000 rpm. Have a new full flow sports muffler on it plus about a 60 degree dump pipe so all the ****e hits the tarmac and not all over the back of the car.
I am stuffed but more emotional than anything else.
Just great relief all the mods work and its going to be a hauler mauler for years to come.
