CMF_White Knight
» CMF MemberWell thats it the stump puller has gone about as far as it can.
Everything working just spot on mechanically and a little old lady could drive it. Power progression is now very smooth as long as you do not well knock her (he?)down a cog and stomp on the pedal.It barks then.Last niggle was pulley belt squeal( slippage) but upgraded the adjustment bracket so can put a bit more tension and adjustment as the belt stretches.Appears after about every 5000 kl belt needs to be adjusted. Belt life?? About 30,000 kl is expected. A lot depends on hard it is driven.Keep it smoooth but fast will be the motto.
So its pimp and shine time and just enjoy. Will organise a dyno run very soon.
