What kind of oil did you use?I changed the oil on my new to me k10, suddenly it started blowing white smoke and running rough. Any ideas as to what it might be? Thanks in advance!
Looking at the inlet manifold gasket, that is a strong possibility........The intake manifold on these also has coolant flow through, it that a possibility in this car?
Low compression universally across all four cylinders would suggest a worn engine, while low compression on one, or two adjacent, cylinders, can point to head gasket failure, though badly seating valves on those cylinders would also give a low compression reading.................My thought was if I have low compression it’s probably the head gasket as opposed to the intake manifold gasket. Would you agree? Any other way to diagnose?
