Morning...and hello
No doubt this has been done to death, but i've just bought a 2002 K11 'S' for my daughter - it's got a noticable amount of gearbox whine.
I've read all sorts of conflicting opinions on how to check / replace the gearbox oil!
On this box, is there a drain plug and a fill plug on the gearbox casing (rather than using the speedo drive)....Does it use bog standard gearbox oil?....Any advice welcome.
It also has the all too common stiff gearstick which doesn't return to center - i assume it's just a case of cleaning up & greasing the bushes as well as popping the spring back on!
Ta
Ta
