Which master cylinder and servo choose ?
Hi,
I'm looking for upgrade my brake system i've already 100nx front calipers and now i want upgrade my master cylinder and servo,
Which set of MC/servo would fit ? Sunny ? Non ABS primera ? the length is not a problem it's an GA16 swapped LHD.
Yeah i've seen but this is an 2 line MC and you need to adaptate all the system. I'm looking for something more simple to fit. I've seen the space between the 4 bolts is 100 for micra and 80 for primera right?
the k11 servo and the p11 servo have the same bulkhead bolt holes.
the primera 1.8 p11 M/C & servo I have here is simply way too long.
other ppl suggested skylines but I didn't have em at hand to check if they'll fit.
most M/C between cars have different port arrangements so ur bound to recreate the whole engine bay brake lines to fit.
Ok thanks, i think i'm gonna buy an primera non abs (or sunny if it's the same ?) servo/MC cause on LHD the length is not a problem
