where to put oil drain?
hi just a quick question to all you turbo micra owners. i'm starting to put together bits and pieces for a turbo kit. i've got just about everything planned. just want some comfirmation as to where people have put there oil drains from the turbo? is the highest point of the sump ok? or is it to low? i have also seen some people disconnect the breather/oil return hose on the front of the motor and drain the oil from the turbo into that.... thats ofcourse only if you turbo is mounted high enough to do so! and help and thoughts would be well appreciated. also does anyone know what cc the standard injectors are? thanks!
CMF_Yom
Hi?
edit: lol mate message snoopy i guess?
