Wheel offset and backspace
CMF_deNs
Total Width: 6.5" or 165.1mm
Total Width - Backspace = Space from centre line of hub to face of wheel
Therefore, 165.1 - 127 = 38.1mm
If the space from the hub face to the back of the rim is 127mm then all you need to do is see how far forward it is from the centre line of the 6.5" rim. In this case, the centre line is 82.55mm. The distance between the hub face and the centre line would be the difference between 38.1mm and 82.55mm. That would give it an offset of +44.45.
That is of course, unless I'm misunderstanding your idea of 'backspace'. I'm very tired and the above may well be incorrect, but if you draw it all out on paper it should start to make sense. Just figure out widths and where the centre line is and go from there.
Also frank, unless you're running huge flares, I think you mean +38 and +45.
---dens
CMF_Polarbear
Thanks Dens, I went looking for instructions on calculating backspace and offset so I could work backwards and for some reason it wanted me to add an extra inch to the 6.5 for like nominal width or something? I dunno it didn't make much sense to me.
CMF_chargeR
deNs WROTE:
"Total Width: 6.5" or 165.1mm
---dens
Polarbear's original calculation is correct mate :). Backspace is not measured to where the tyre bead sits like wheel width is, it is measured to the extreme inner edge of the wheel which is generally 1/2" further in than the inner lip of the wheel. So a 8" wide wheel with zero offset will actually have 4.5" of backspace, not 4" as you might think, and the 8" wheel will actually be 9" wide from outer extremity to outer extremity (the nominal width).
Of course converting to offset from backspace is not extremely accurate becauuse not all wheels have an outer lip 1/2" thick.
I use this wheel calculator to compare between the two measurements: http://www.bigcustomwheels.com/rt_specs.jsp
CMF_deNs
chargeR WROTE:
"Of course converting to offset from backspace is not extremely accurate becauuse not all wheels have an outer lip 1/2" thick.
That's what I couldn't understand - I was sure that not all wheels would have such a standard but that's handy to know about how the proper width is calculated. I guess that means that the set I originally thought was 7" wide is actually 6" wide as I measured it from edge to edge as you've described. They never did seem like they were how 7" wide wheels should be.
So Polarbear whichever calculator you used was right in at least assuming that bit extra it had to calculate for the 'backspace' and since my post above didn't take that into account for the offset, I can safely say that both you and chargeR are correct here ;)
You learn something new every day!
---dens
CMF_Polarbear
Haha I didn't find a calculator, I just found the info and equations and worked it out.
Ok guys, good to know I didn't stuff it up.
And that should be fine for a micra? I recall reading that the offset should be between 35 and 42?
Closer to 0 moves the rim... inwards?
CMF_deNs
Outwards (again, if I'm interpreting it right). Moving closer to 0 will increase the track of the car and bring the edge of the rim closer to the guard. This is a good thing :p For 6.5" wheels you can go to about +15 to +20 without much worry, though for +15 and below you may need a slight stretch and/or negative camber on the tyres. I really can't remember. I know chargeR's running 13x6 +24's which bring it relatively flush with the guards, as an example.
The more + offset you have, the more inset the rim will be, the worse it'll look and the closer it'll get to the strut.
---dens
