L
leicesterminiracer
Hi
Ive had to replace my o/s/f wheel hub, did u know that the 2001 micra has two different configurations for the hub, they are virtually the same when you look at them, but the main differences are:
1 - Auto hub will not fit manual car, as drive shaft spigot is smaller
2 - 13 inch wheel hub will cause the ball joint (the threaded bit) to rub against the CV joint once fitted if used on a 14 inch wishbone.
These are the probs ive had
