i have 1995 micra 1.0 and i have replaced ignition control module 2 times, 1 non-OEM and 1 Lucas OEM part, and when i replaced OEM one i replaced also ignition coil, rotor, distributor cap and ht leads. it did work for maybe 2-3 hours just fine but then it started randomly jerking. later i got fault code from camshaft position sensor. only thing i think what could have caused this is i didn't put silicone grease (which came with control module) between the metal plate and ignition control module.
Thanks for help in advance
