What size exhaust?
CMF_david (2)
For GeoffW's car when it says 2" exhaust, does that mean for the last meter or so of the exhaust system, or did he also have the extra catalytic converter removed and a larger pipe from the manifold to the muffler?
Did he have a 'high flow' muffler?
How much of the exhaust system from the engine/manifold to the tailpipe does this 2" refer to?
Forgive my ignorance please.
It does appear that the best single thing to improve torque is to increase the exhaust to 2" (whatever that means).
What is the standard size exhaust on a micra k11?
CMF_frank2
the 1st cat exit is 39mm inside dia david, then it drops to 34mm at the downpipe then drops further to 31mm where it joins the 2nd cat (due to a reinforcing collar inside the flange)
the rest of the system varies from 31mm bore to 35mm depending on make/brand
so the downpipe is very restrictive imo (where the gasses are still hot and expanded) and i went for a modded mani, 2nd decat 40mm bore system throughout :)
(which gave me .003% CO emissions)
frank
