What do I need for a bike carbs set up on K10 1.2?
Hi all
This has possibly been asked before, but what exactly do I need to put bike carbs on my K10 1.2? What parts would I need? What are good carbs to go for? Would there be a significant power increase?
Any advice appreciated.
Irc youl need a custom intake mani a way of plumbing in the vaccum lines and a bit of fiddling with the throttle cable and youl need to get them set up properly on a rolling road what carbs are you thinking of using
i think the cbr 600 carbs are a common one ive got a set sat here with a stuck choke that i was going to use on my cg conversion. you need a manifold cost me £90 to get one made, you will need a fuel pressure regulator and then its just plumbing the vac lines and acel cable up and away you go:) but as said they will need setting up which can cause you a headace if not done properly
