What alloys fit the k11 on a R reg
4x100 yes, centre bore has to be 59.1mm at least, any smaller they need to be re-bored or have spacers, any bigger and you'll need spigot rings.
13's, 14's and 15's fit, depending on the width and offset. 16's are hard to pull off and 17's are for Saxo's wanting to be in 1998's edition of Max Power.
Pretty much everything other than nissan alloys (though also be aware that some nissan wheels are 4x114.3 pcd) will need some sort of mod, either centre bore opening up or spigot rings fitting. Both these are easy to overcome, spigot rings from £6.00 on ebay and flap wheel to open wheel centre.
Tell you what, you find some wheels that you like, post the details and specs on here and I'm sure somebody will let you know if they fit or what mods may be required ;)
