CMF_freecookies
» CMF MemberI washed the car. I also dregreased the engine and hosed it down, relatively high pressure.
Upon starting the car, it began to make a tapping noise, rapid tapping. My first though was tappet noise, just guessing here. The sound becomes louder and faster as I rev. When driving, power is not as it was before, slower off the mark, rougher, as if a piston had cut out.
I also thought it could be a timing chain issue, it has done 203 000 ks, but there has been no noise really. A bit on start up for about three seconds then it would stop, i assumed it was just the tensioners taking up the slack.
Temperature is fine, no overheating. Still drives, but smells a bit burnt. And the power loss.
Maybe a spark plug issue, maybe timing chain, maybe tappet, maybe somehow water got into the engine ?
Im 17, Im not a mechanic, just guessing here.
Any ideas or suggestions ?
Thanks in advance for all replies posted.
-freecookies
-freecookies
