A
andy288
My 91 K10 is leaking water badly now from the waterpump area so gonna change it. Anyone done it already - advice on the pro's and cons gratefully received.
Also, the Haynes 'destruction' manual says sealant needs to be applied to the threads of the pump mounting bolts when refitting to prevent water leaks, any advice on what type/brand etc to use and the time it takes to 'cure' before refilling the coolant? :suspect:
