CMF_Alex_B
» CMF Memberi've been reading up on autospeed about water injection options...yes lookout peoples Can mighty, white knight and others shed some light on their setups/experiences, some do's and dont's?
i have some questions to kick off:
1. are you lads using a boost pressure setup, or running it of the airflow meter output voltage with a controller/computer?
2. Where is the injector fitted?
3. how much water do you use per tank of petrol and what boost pressure/engine load does it cut in at?
4. i think your both using off the shelf kits, which ones?, any I should aviod?
reason im asking is i'm thinking of doing away with the intercooler all together. i have read water injection restores the power one would have without any heatsoak i.e. like having ambient air entering when its spraying. hence works just as good as the intercooler, but at lower cost, see i must have a nice smoothed in in bonnent scoop above the topmount(keeping AC) and that's going to boot up the price, along with custom mounting brackets. going water injection i can do a family hack, just have low boost 4-5psi until i get funds to add in the water injection and bump up too 7-10psi.
also does the micra AFM output a voltage 0-5v or a frequency singal?
thanks in advance,
Alex
thanks in advance,
Alex
