Hi guys
Just wondered if anyone ha had a problem with water entering the car from the sunroof area. Its a 2004 K12 SE.
The seal is fine on the sunroof, but when it really pours down, the cloth above the door gets soaking. About 6 months ago, I checked it out and it was a pipe that had come away near the sunroof. I blew it through with an airhose and reattached it and it had been fine since.
I just wondered if anyone else has had similiar problems. I havent had a chance to check the pipe again, will do tomorrow.
What Ive learnt about the micra is that its normally a common fault, as was the timing chain, reverse sensor, cam sensor, interior light, fuel filler pipe, battery connectors, fuel pump ...the list goes on!!! Good fun tho. Only the alternator to go and thats about it!!!!
Any comments appreciated
stumpy
stumpy
