My washer pump has recently stopped working.
I've disconnected the water pipe where it feeds into the jets and no water is coming out of the pipe when the pump is activated - so I know it's not blocked jets.
The pump is making the usual noise when activated, so there is power to it.
Looking in the Haynes, I see that Fuse 24 is for the front wash/wipe, so presumably that means the wipers and washer motor are on the same fuse - the wipers are working fine, so the fuse must be OK.
It sounds like the only thing left is to replace the washer motor - or am I missing something else to try before I do that?
Thanks guys.
Thanks guys.
