Lubed them up and also went for some shock unlock. Which has worked in everything else no issues. They started couple of turns them that feeling when you know they are going to shear.
May have to drill and tap maybe stud extract if I can't find a cheap cat.
Any tips for the lambda sensor I could do with a 22mm spanner. I have seen someone mod a deep socket with a slit up the side for the wire.
Spanners are pretty cheap.
You'll find it'll be far easier just to buy a spanner off ebay for a couple quid rather than trying a MacGyver inspired idea.
